Thread: Your Suspension Setup
Page 7 of 14 FirstFirst ... 34567891011 ... LastLast
Showing results 121 to 140 of 280
  1. #121
    10-24-2003
    1,432
    I didnt think of that, I know the firewall is extended on the eclipse. Would there be any method for ridgedly making an extention bracket of sorts.
    www.gooichimotorsports.com
  2. #122
    Quote Originally Posted by 6G72gearhead
    it's been thought of but nobody is sure if the 8g firewall is structurally capable of being an anchor point for bracing.
  3. #123
    10-24-2003
    1,432
    It depends on how much the strut towers flex, I might have a solution to figuring this out. But I would mount it to the seem on the firewall that should be a strong point.
    My Idea to see how much they flex. drill a piece of sheet metal to fit under one of the bolts on either strut tower. Connect a rod on either side, pvc tubing would work to. then with the smaller rods attatched to the strut towers, connect them with a larger tube that allows the rods to telescope inside of it. Take and secure the larger tube to something that wont allow it to move at all, as any movement of this piece will flaw the results. Now on the small rods mark a ring all the way around where the larger tube starts. then get two markers and secure them on the larger tube with the tip of the marker riding on the small rod, then with a different colored marker, mark a ring where the marker tip rides. Do this on both sides. Then go drive the piss out of it with a full tank of gas and then look at the results.
    Think of what I have done as a dampener. With the dampener in its still position, we have marked where the piston shaft is in relation to the outer dampener tube, also we have a marker riding on the piston shaft, marking its up and down traval, we also have a mark where the marker is placed while at rest.
    Now we would know how far the strut towers flex, and can then make a more educated discision as to whether or not the firewall can hold up.
  4. #124
    - Megan Racing Full Damper Coilovers
    6 clicks in the front
    9 in the back
    - RRE Front Strut Tower Brace
    - 18" Falken Koblenz wrapped in Bridgestone Potenza 225/40/18
  5. #125
    12-14-2006
    New Zealand
    823
    Galant: 1994 VR-4 V6 TT
    Springs: TEIN Coilovers with Dampening kit
    Wheels: 17" TSW Evo R (Can't remember the exact size)
    Tires: 215/45/R17's Bridgestone MY01
    Other: Cusco Front Strut Brace
    Compared to the standard setup, I found the suspension to ride so much smoother.... cornering is a breeze now and stopping distance has decreased.
    All an all, the TEIN setup is the best I have come across for the Galant. I used to work for mitsubishi, and most of the other setups I came across were far too hard and the car jumped all over the road.
    I'm looking into a camber kit for the car in the coming months, so I'll keep you posted
    1995 FTO - V6 Mivec 200hp
  6. #126
    2000 Galant LS
    OEM everything with the exception of:
    Megan Racing 3G eclipse front upper strutbar.
    eBay rear lower tiebar.
    (dry months) Monderra 20" steel/chrome Blackhawk wheels on Nitto NT-555 Z rated tires (225/35ZR20 90W).
    (wet months) 5Zigen 18" alloy Super Six wheels on Nitto NT-SN1 winter rated tires (225/40R18 92V).
    Worlds better than 100% OEM already. I'm learning to love my 5Zigens over the bigger and heaver Monderras. I'm thinking about switching to 18" alloy wheels all the time on the road and just put the chrome on for shows and such. The NT-555 tires are the coolest tires I've ever had the pleasure to drive on. They stick when you want them to and seem frictionless when you don't.
    Next upgrade is either going to be the D3 chassis stiffening kit or Tein Superstreet dampers with the EDFC. Thinking I need to replace my strutbar with the Tein/Carbing one with the master brake cylinder stopper.
  7. #127
    08-06-2005
    Long beach/ guam
    1,585
    3 300 lb chicks at the rear, two giant balls in the front.. got me 2" front 1" back.
  8. #128
    Year: 2000 Galant 2.4L
    Megan Racing
    KYB-GR-2
    SPC camber kit
    3G Eclipse rims 17x8 (i'm not sure about the width)
    205/40 R17's
    3G strut bar, rolled rear fender
    Everything I've done to the car so far seems to being working out real good. The springs and struts give the car a good ride. Not too stiff, but not too bouncy either.
  9. #129
  10. #130
    Proto
    The 2G shall have the following:
    - Eibach Prokit
    - Tokico Illumina Shocks&Struts
    - DC Sports CS2 Front and Rear Strut Bars
    - RM Rear Sway Bar
    looking into under body braces also.
  11. #131
    05-25-2006
    New York City
    1,028
    Quote Originally Posted by milo111000
    lmfao :D
    2000 Galant ES = Daily Driver
  12. #132
    hey could anyone tell meany sites to get affordable but good struts/shocks?
  13. #133
    02' Galant ES i4
    Tien S-tech springs
    KYB GR-2's
    93' Probe GT STB
    Ingalls Camber Kit
    18x8 5Zigen 5ZR 2 piece 225/40/18 Offset is from a 91 supra, probably a 38 maybe, not sure
    Not a bad setup, I think the Tein's are a lil mushy, Planning on ditching the whole setup and running Tein Basics.
    Zigen look fine, but im searching for some SSR GP-0 Evolutions. If I can find them, im buying them.
  14. #134
    Experienced TGC Member glantv699's Avatar
    04-14-2005
    PA
    1,046
    1999 ES V6 Galant
    Sprint Lowering Springs
    KYB AGX Shocks/Struts (set on 2 all around)
    Freedom Design Strut Tower Brace
    18 x 7" Finn Racing Wheels with Kumho Ecsta 711 Tires
    The drop is amazing thus far, the springs are rated to -1.8 for the front and rear. I think I got way more in the front. 2 finger gap in the front and 1.5 finger gap in the rear well.
    Handling is sharp and the ride is a little rougher, but the tires stay planted on the road. I am quite pleased with the setup thus far, I need to get an alignment probably, although it really looks like not much changed.
    > TGCPA - SOUTHEAST
    > 1999 ES V6 (Sold 2/2011)
  15. #135
    07-23-2004
    San Diego, CA
    1,496
    Quote Originally Posted by dronesurfboards
    02' Galant ES i4
    Tien S-tech springs
    KYB GR-2's
    93' Probe GT STB
    Ingalls Camber Kit
    drone...got a pic of the stb??
  16. #136
    ill take a pic of it when i get a chance this week
  17. #137
    2002 I4 ES
    Tein SS-P
    DC Sports upper front strut bar
    Ebay rear lower tie bar
    Ingalls camber kit in the rear
    18 inch Axis Reverbs
    225-40-18 Nitto Neo Gen Tires
    Love my setup
  18. #138
    would anyone be able to tell me where i can get some KYB-GR-2's, i just bought some megan lowering springs and im looking to get it all done soon, thanks alot
  19. #139
    1997 DE 5spd
    Eibach Prokit
    KYB GR-2's
    2G strut tower bar
    DriftZ 17 X 7 40mm offset
    Federal SS 595
    14mm rear swaybar
  20. #140
    8G_GTZ
    UPDATE:
    Megan Racing 32 Way adjustable coilovers
    Megan Racing Strut tower bar
    18x8 Motegi Racing wheels
    225/40ZR18 Falken Ziex 512
    On order:
    Intrax lower rear sway bar
    Powerslot EVO 11" rotors
    ebay rear lower tie bar
