Thread: EC5A VR4 Brake Specs
Showing results 1 to 3 of 3
    wildfaye
    Hi, my name is Sam. Just got onto this forum.
    I have some queries with regards to the 1999 EC5A VR4 brakes.
    Was wondering if anyone can help?
    Need to know the following details:
    Front Rear
    No of pots(caliper)
    Diameter of disc
    Original Thickness of disc
    Min. Thickness of disc
    Centre Hole
    Original Height
    (total width of the disc/hat)
    Thanks in advance!
    Cheers!
    gssplaya
    hmm
    the brakes are 10.8in rotors mated to dual piston calipers.
    please join us www.clubvr4.co.uk if you got a VR4!!
    cheers!
    wildfaye
    Hey! Thanx! I am in there as well.
    I have a FTO, not VR4, hope you guys welcome me.
    Requesting the specs because would like to upgrade to VR4 brakes.
    Brembos from Evo don't fit because I intend to keep 16" wheels.
    So far I managed to source the following
    Front: 294mm x 24mm (Ventilated), 5x114.3, Two pot Caliper
    Rear: 284mm x 20mm (Ventilated), 5x114.3, Single pot Caliper
    I intend to get cross x drilled rotors so need exact specs/dimensions.
    Hope someone here can here me...
    Thanks alot!
