Thread: no injector pulse
Showing results 1 to 5 of 5
    08-24-2002
    950
    no injector pulse
    there is no injector pulse for my fuel pump. i know for a fact. so what do i do now? please urgent help!
    injector pulse for your fuel pump?
    those are two totally different things. Do you have no injector pulse (at the fuel injectors), or have no power to the fuel pump?
    08-24-2002
    950
    <div class='quotetop'>QUOTE(manybrews)</div><div class='quotemain'>injector pulse for your fuel pump?
    those are two totally different things. Â*Do you have no injector pulse (at the fuel injectors), or have no power to the fuel pump?</div>
    a mechanic said i have no injector pulse
    and u can't hear my fuel pump turn on so i made an assumption it was the same.
    but yeah, no injector pulse. so what do i do now?
    could be a dozen different things.
    distributor failure.
    computer failure.
    wiring issues.
    blown fuse.
    etc.etc.
    of course, theres always the chance your mechanic is wrong, too.
    Honestly, this is one of those many problems that cant be fixed over the net, I think.
    ConceptSleeper
    i had the same problem when i first got my galant, it turned out to be the wiring to the injectors,i would wiggle the wires and it wouldnt start unless i had the wires in a certain spot, plus the wiring and covers were cracked from the heat, long story short i just replaced all the wiring to the injectors and im good to go!!
