it depends on what you are runnin, but the Walbro 255 lph is the most common. i have that in my gride
ok I have been doing some research on the Fuel Syspem trying to avoid the Stand alone and I have ran into the Walbro 255 for the 2nd Gen eclipse. Now another option would be the walbro 190, or the Zex inline pump. I was just curious to see who has another fuel pump. and how hard it was.
C.J. Cameron
RETIRED TUNER!!!!
"Keeping it Simple"
that is what i am using too -warlbro 255lph
Check out my ride at:
the 255lph is an intank pump ryte how hard is it to install ive droped the gas tank before so thats not a problem im just wondering about the wiring... oh yah what type of fuel pressure regulator would you guys recomend? a rising rate or adjustable for turbo ofcourse :twisted:
You don't have to drop the tank to replace the pump. Access to it is under the back seat. The wiring is all there, along with the pump when you remove that steel plate on top of the tank. You'll see it when you take the seat out.Originally Posted by Whips_n_chains408
I recommend the Rising Rate FPR that Vision Imports and RPW sell. I had it on my car and it works really well and is adjustable to somewhere around 75psi.
Chip
(Paint Code: Porsche LC9Z)
thats even better i always wondered what that metal plate was
Just like Dj and GTZ, I am also running the walbro pump, w/ the Vision FPR..
if u install a new fuel pump i suggest u do some rewiring w/ some thick guage wire to give the new pump some nice voltage
SO noone here has the Zex? or heard anything about it? I will more than likely go Walbro 255. But I have Chips RPW Rising rate and it's great. took some getting use to and has some problems in teh beginning but I'm good now.
C.J. Cameron
RETIRED TUNER!!!!
"Keeping it Simple"
Hey Laz I have read about the booster fuel pump from Zex....but I don't know any who is using it with their system......there website doesn't really talk much about it neither....
ok for all those that are interested Extreme PSI has them for $95 Which I think is cheap as hell.
C.J. Cameron
RETIRED TUNER!!!!
"Keeping it Simple"
C.J. Cameron
RETIRED TUNER!!!!
"Keeping it Simple"
