Thread: 7G CAI Tutorial! n00bs read!
Showing results 21 to 40 of 52
    maroonmonster7G
    cai
    can ne body tell me if their were noticable changes in sound and performance after installing the gsr kit??.....mine is on the way and i wanted to make sure it was really worth it......can i use one of the three pieces as the tube between tb and mas?
    you will definitely notice the sound. u may or may not notice the performance gain, but its a good place to start regardless
    7G-Redsand
    Sup, Im new and i was wondering if this 94-01 Acura Integra GS LS RS Cold Air Intake http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2434439514
    would fit for my 97' galant
    Thanks
    eh tahts not the one everyone uses, but you could cut it to fit. you would need to make about 3 cuts, but it could work
    pornstar
    i duno if this would jus be too much work
    but couldnt you jus buy piping and rubber pieces from home depot?
    and whats the difference between a cai and a forced air induction?
    mjc1055
    cold air would be your intake, forced induction would be a turbo/supercharger... only a slight difference in cost and performance
    pornstar
    o... ok thanks
    i saw a guy with home made 3" pipes that i gues was just a cai but he labeled it "forced air induction"
    yea u can use pvc piping but its not called pvc its called something else... its like 59 cents a foot i think...
    uhhhh...... Whats a 9g???
    don't use the plastic pipe from home depot. the pcv and other plastic pipe at home depot won't hold up to the heat.
    ive had mine for more then a year with 3 reducers on it... seems like the reducer is more likely to melt then that though... cant say about the hot air though...
    pornstar
    wut r the reducers? the rubber adapters?
    but other than that... 59 cents a foot sounds good
    i think im mite try to do that, hopefully find 2 pieces i wont have to cut, and see how it works out
    if it doesn't work, i'll have lost a couple bucks and i can still buy the integ intake
    so if anyone knows the name of the pipe that would perform best under the heat lemme kno
    youll see it its not that hard to miss... mine is colored black... but ya no matter what, ur gonna have to cut but its no biggy and ya the reducers are the rubber thingy...
    pornstar
    15$ intake and its awesome
    can def feel the power and hear the sound
    the first two times i put it on it was too low and the filter fell off but now everything is set
    but im jus curious... how low should the intake be? should i be able to see the filter by looking under the car? should it stick out below all the other stuff?
    Slut
    where can i buy the MAS adapter and what kind do i need?
    eBay usually has em. and they make am in 3" and 4.5". 4.5" is more common, but 3" would be ideal
    pornstar
    no u already have that... thats ur maf
    ur looking for something like this
    http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=38634
    xSILENTx
  19. #39
    GalantsArePoopy
    if i get an integra gsr CAI kit, all i would need to buy to use it on the galant is the MAS adaptor for the galant correct?
    where can i get just a MAS adaptor? on ebay they come with a filter, but i dont need a filter cause the CAI for the teg comes with one.
    also, is this way cheaper/better than building tha CAI like the original guide explains?
    can i use the MAS from any eclipse models? cause then i could buy an eclipse CAI.....and just cut the piping so it fits
  20. #40
    does anybody have pics of the gsr intake already installed in a 7g?
