Thread: Please help me
Showing results 1 to 4 of 4
    MitsuChic
    Please help me
    Can anyone tell me where the voltage regulator is located on my 91 LS?
    Senior TGC Member
    07-31-2002
    Sugar Land, Texas, United States
    2,175
    Holy crap...come on 6gers, I know you're out there somewhere.
    Best place to look, is in a repair shop manual, you probably pick one up from Ebay. Or you can try to PM Manybrews, our resident Tech
    ConceptSleeper
    if you remove your alternator and look on the back of it there will be the voltage regulator/brush holder assembly, to remove it just take out the two mounting screws and it will pull straight out.
