Thread: 1991 Galant 2.0 non-turbo oil burn
Showing results 1 to 9 of 9
    91GALANTDRIVER
    Engine is burning oil can be seen in smoke out of tail pipe after car has been sitting over night or longer can also be seen sometime when shifting it is burning the oil slow need to put some oil in after a 100 miles or so. thanx for replies. God Bless
    ConceptSleeper
    sounds like the piston rings to me!!!!!! how many miles you pushing??? hmmm...rebuild or to swap is the question?!
    91GALANTDRIVER
    Quote Originally Posted by ConceptSleeper
    175,000
    ConceptSleeper
    yup piston rings, common on our cars!!
    JF
    yeah i'm almost at 180k and have the same problem......
    dirtyspence
    Yep same here at 150k... it slowed/stopped for awhile when we replaced the head and gasket ,but, came back after a few break in miles. Nothing major just an occassional puff...
    actually, smoke upon startup and extended idling is going to be from worn valve seals / guides.
    very common.
    If you replace the head with a rebuilt , will it come back? how soon?
    10-05-2008
    Grand Rapids Michigan
    1,141
    6g's unite !
    ps i dont own a 6g
