AEM sells cams for 7g........pulleys i dunno...
I want to get all new cams and pulleys for 7g. My question is, is it worth the money and the labor, and what will i see out of all of it. If anyone has done it. If you know of a site that is selling them pls leave me the good name thank u
Is buying the cams worth it though. I know they sell them but will they work really well on the 7g
well since there is only onecam (SINGLEoverhead cam) i dunno, i would say yeah because it is a sturdier lighter weight cam designed for high performance...
It depends on what you get.
You will want a new cam gear also in case you want to advance/retard the timing of the new cam. My best advice is to get a stage 1 or similar cam if you don't have any other internal work done or else your car will run like shit.
Unorthodox Racing sells pulleys for the Spyder ('96-'99) that will fit our cars. Just hit up their website.
R u sure the spyder will fit. I know we have the same type of engine setup but r the pullyes all the same or is it on particular one,
The spyder engine is the same engine as ours. Except they use DIS and have no distributer. I think RRE sells a new camshaft for the sohc I think Curt might have bought it, or thought about it, you could get adjustable cam gear but I dont know if it will do much for an sohc.
The pullys will fit, but I think your not suposed to use the crank one because it has no harmonic dampener on it and will bust ur engine up.
Rob
rIp 97 Galant
starting over.
90 Talon
I emailed Unorthodox about this and this is what they said:
-----Original Message-----
Sent: Tuesday, July 08, 2003 1:27 PM
To: '[email protected]'
Subject: Mistubishi 4G64 pulleys
I own a 1996 Mitsubishi Galant , which has the same engine (4G64) as the
'96-'99 Eclipse Spyder. I was told that I could not use the crankshaft
pulley because it lacked a "harmonic balancer". Could you please clarify
this for me? Thanks.
Please read our FAQ section for the facts on our pulleys, what you've heard is an urban legend.
Thanks for your interest,
UR
Well if thats the case then no prob =D
Rob
rIp 97 Galant
starting over.
90 Talon
so i can get a new pulley and cam set but i cannot use which piece again because it does not have the harmonic what :? :? :? :? :?
He was talking about the unorthodox pully, but it's been confirmed that it does work and will not bust your engine. Get it, along with some 325cc injectors from a non-turbo 3000gt/stealth and a 1g 60mm throttle body and a massive cold air intake, along with an s-afc to fine tune everything, your car could easily shave a few seconds. Especially with header, 2.5" exhaust, and a better ignition system.
Just a heads up, but @ UR's website they have a specials section. Under this section they have Alt, P/S, and W/P pulleys for the 95-99 eclipse turbo. I crossreferenced the part numbers w/ those of the '96-'99 spyder and they are the same. Just wanted to let you know because they are going cheap, if I remember they were $40, $50, and $80 respectively.
I wish I had some loot. :x
Who's website are you talkin about
UR=Unorthodox Racing. Sorry, I don't know the website URL off the top of my head.
that site only shows the dohc galants not the 7g galants
You were looking in the wrong place. Scroll down and look for the 95-99 Eclipse. They have the alt., P/S, and W/P pulleys on special.
http://www.unorthodoxracing.com/specials.html
For the underdrive pulley look here:
http://www.unorthodoxracing.com/mitsubishi...hi_eclipse.html
Scroll down until you find the section for the '96-'99 Eclipse Spyder.
