tar burns
does neone know how to remove tar burns from the cushion aorund the door locks....i don't know the name of the thing, but i ahve tar burns on it and i need to figure out how to remove it....the color of my cushion thing is gray...i hope u guys know wat im tlaking about...i need all the help i can get
you mean the door panel?
tar burns? like cigarette burns?
if its the door panel, you can replace that yourself with some fabric from the fabric store, but it'll take some work.
need to unscrew the panel, unpop it by pulling it off, then lift up on it and slide it out to take it off the door. once you see the other side, you'll see it needs to be taken apart with some screws, some areas need to be cut like the plastic holders... etc... if you mean door panel that is.
