They are the EXACT same part number from mitsu. They are filling you full of hot air. There are members riding on them right now.
Wes
Does anyone have KYB fronts yet?
I called up a couple of places to see if I could order KYB shocks and structs today. And the response was: It's still under development. So I said to him the 2000 Eclipse shocks and structs has been released and will fit the Galant. He said to me there are minor differences between the two cars. He also said the Galant shocks and structs will be out next month. Will it fit the Galant?
Wes
Another fine post brought to you By:
The Man™
Search the boards first please!
front left - 734020
front right - 734019
what the when the hell did the fronts come out? ive been off for a while havent had the chance to check my front stox are damn near dead so anyone know where the hell to get em?
- Atba
They are national backorder now. They do exist, there are 3G eclipse guys with them right now. I am pretty sure that tirerack sold out (I would check though) and RRE might have some still.
-Mohammad
RRE does have themOriginally Posted by mochanges
i got mine from Discount Tire Direct...
Yep, they didn't expect the demand to be so high and their production was sold out as soon as it was released. Should be back ordered for months but keep checking.
I wish some other manufacturers got the queue from KYB and get on the ball to get their act together. It would be nice to see other manufacturers give some other options. I personally think they KYB AGX's are too stiff from what I keep reading but that's just from other ppl's views.
Yeah Mike at RRE actually said the Koni inserts are better, that's cool with me cause that's what I have. Also, the Teins have been mentioned, but in any areas where it snows or where the roads are salted, they may corrode. That's not what I want to spend my money on, I'll probably stick with what I have (Koni inserts, AGX in rear, and H&R Springs).
-Mohammad
<div class='quotetop'>QUOTE(mochanges)</div><div class='quotemain'>Yeah Mike at RRE actually said the Koni inserts are better, that's cool with me cause that's what I have. Also, the Teins have been mentioned, but in any areas where it snows or where the roads are salted, they may corrode. That's not what I want to spend my money on, I'll probably stick with what I have (Koni inserts, AGX in rear, and H&R Springs).
-Mohammad</div>
what are the part numbers for the AGX rears...?
Hmm, not sure, they are the same ones as the 2G GSX Eclipse, if that helps at all. I don't have the part numbers unfortunately. Sorry.
-Mohammad
<div class='quotetop'>QUOTE(mochanges)</div><div class='quotemain'>Hmm, not sure, they are the same ones as the 2G GSX Eclipse, if that helps at all. I don't have the part numbers unfortunately. Sorry.
-Mohammad</div>
yup, that helped... thanks...! :thumbsup:
When are they getting more?
<div class='quotetop'>QUOTE(GalantT3)</div><div class='quotemain'>When are they getting more?</div>
check out my post in the GB forum... they are going for $380 for the entire set shipped...
i just ordered a set from rre so guys id say go for it through them i waited months to get the fronts and soon as i heard about it i called them up mine should be on the way soon cant wait to put them on since my stock fronts are preety much dead so thanx for the heads up Mo
- Atba
No problem, see tiller, when people try to help you, you should be nice to them. Ah well, some people just had deficient upbringings where they didn't learn manners. What can you do?
-Mohammad
