Nice, it looks good bro. Im glad you finally got it, and already making good use out of it! Enjoy!
Look at what the brown santa got for me today. These pictures don't do it justice.
Of course it doens't fit. At least not yet.
I am not worried about it sticking out. I can solve that when I get the shop to put it on. There going to need to drill new mounting points in the back. What I need to know is will JDM headlight fill in the gap between the grill and the headlights. There is about a 2 inch gap on both sides.
Or do you guys think the VIS kit will take care of that for me.
I would also like to thank Mike. You know I got you bro...
im glad u got it bro. It looks good. Can't wait till it all comes to place
:shock: :evil: *jealous*
the jdm headlights will fill in the gaps on both sides...
All right then JDM headlights it is then. Now can some one tell me the difference between the 2 Piece or the one piece headlights I keep hearing about?
Reelax can you tell me how hard it was for the shop to put on your grill or did you do this yourself?
the two piece headlights have seperate corner pieces for the turn signal. kinda like how the 6g galants are.Originally Posted by Prophet
the downside to them is that its hard to find the clear corners sometimes. since they are an aftermarket part. if you wanted clear corners with the two piece, you'd have to located a place that sold the piece unlike the 1 piece headlights. with the 1 piece headlights, you just open up the housing and take that bad boy out.
OK so I am going for the one piece then. Do these JDM headlights come in HID also or is that a aftermarket part also?
that grill looks hot cant wait to see how it looks installed
i dunno about now but before, the jdm's came with just regular halogen bulbs. i know when reelax got his, his didn't come with a harness or anything, just the headlight.Originally Posted by Prophet
my set came from taiwan via GDImports (galantesp) and had NO harness but you really don't need it. you can just clip in the bulbs and connect them w/ female spade connectors tapped into the OE harness. when u get them i can give you more info on the re-wire from H4 to H7low/H1hi. it's not too bad... cali and mochanges are running the wiring scheme i gave them and so far it is working great. i converted my JDMs to low beam HID H7 b4 i installed the housings but then went to full dual beam HID (H7 & H1) shortly after and, as a precaution to have enough direct current at all times, i upgraded to a custom made, heavy duty wiring harness and relay network for my HID's... this i realized after the fact was completely overkill.
The grill looks good bro, hope it all works homie..
