Thread: 1999 Galant Fuse Box Pictures (dash and firewall)
Showing results 1 to 4 of 4
    mastercall
    I am having a rough time with a 1999 Galant that I recently puchased (mitsubishi auto auction).
    All of the fuses and relays were pulled and most were not reinstalled. After an hour with the owners guide and the backs of the fuse cover it is now functional but not 100%.
    I was hoping that a person with the same vehicle (1999 Galant 3.0 V6) could supply a picture of both fuse boxes (dash and underhood). This would allow me to compare what fuses and relays are being used in a functioning 1999 model.
    Thank you
    CT_GalantV6
    click this link=Fuse Locations on a '99 V6
    Hope this helps u
    mastercall
    Thank you for taking the time to place the pictures of the fuse positions. I am still working on the problems and it appears that I may be suffering from a reverse polarity jump that took out my ECU, alternator and cluster!
    CT_GalantV6
    Glad to help, I hope it all works out without to much trouble.
