i'd do it every 30k. not only does it give the tranny some new clean fluid, but will also give u some kinds of signs of transmission problems like maybe metal flakes in the fluid or something. and yea diagnosing the problem early is good because u might still have a chance to fix that problem instead of replacing it.
you can do it sooner if you want. but thats totally up to you. if you wanna dish out the money to do it every 20k or so its up to u. but u could be using the money for mods. but then again yea if you are having problems or you find some, you might want to do it a lil bit more often to see if the problem is getting worse, better or whatever.
