Thread: nitro miles
Showing results 1 to 6 of 6
    08-24-2002
    950
    nitro miles
    curious, how many miles at the max should you spray?
    09-22-2002
    Kissimmee, FL
    1,495
    Re: nitro miles
    <div class='quotetop'>QUOTE(Proud Galant Driver)</div><div class='quotemain'>curious, how many miles at the max should you spray?</div>
    Do you mean how many miles your car handle on the bottle? Or can you spray for miles at a time?
    b-boy_sky
    If you are talking about how many miles before the engine goes then there are rules that you need to follow if you are spraying so that you don't blow your motor. If you actually follow these rules (not everyone does) then your motor should hold up fine without any problems. You have to keep in mind that every motor goes at some time.....
    stick to quarter miles, more than that and you'll be going 100+mph anyways
    I'm pretty sure he means is it still safe to spray when you have a lot of miles on your car, if the engine and stuff will hold up or whether it will cause damage cause of the wear already placed on it..
    -Clay
    2000 Kalapana Black ES V6
    White 18 Katana Concept 10's.
    B&W all the way!
    HiperSilver
    Nitrous-Use it when you race only, quarter mile, flying mile whatever
    You dont need to use nitrous daily, in traffic or streets. Thats why u will kill you motor sooner
