engine tranny question........performance....
building a 6 bolt 92 eclipse turbo motor, i know the 95-99 turbo tranny is no different than the galant (mounting wise) not sure about the 1g...do i have to use a 1g eclipse tranny??
Member
if you have a 7g, you have to use the 2g eclipse turbo trans, the 1g trans will not work because it doesn't have the front or rear mount on it, unless you want to drive around on 2 engine mounts, but i really wouldn't suggest it
2 less mounts? that's less weight!! whoo hoo! lol..just kidding, thanks a lot....guess that means a 2g tranny computer too?
Member
sorry, don't know too much about the automatics
