Thread: clear corner 8g?
Showing results 1 to 8 of 8
    xtrememarine
    clear corner 8g?
    where can i clear my corners on my 99
    Jeff
    in your driveway
    Baltimore, MD
    2,848
    In your driveway, in your basement, basically anywhere.
    Seriously, use the search engine. There are a number of tutorials for clearing 8G corners.
    Chip
    (Paint Code: Porsche LC9Z)
    Jeff
    barely beat you to it Chip
    xtrememarine
    Re: clear corner 8g?
    [pray for peace train for war :twisted: ="xtrememarine"]how can i clear my corners on my 99[/quote]
    xtrememarine
    any sites in mind
    Jeff
    alright...take off your grill and your entire headlight assembly. take out the corner and headlight bulbs. use a screwdriver through the turn signal hole and pry up the amber piece. once you get it off, use needle nose pliers to break it up and dump the pieces out of whatever hole you can get them out of. there's much more in depth instructions on the board...just search for "clear corners." good luck and welcome.
    This is a DIY mod and has been asked plenty of times. I have provided a link to help you out.
    http://tgcny.galants.com/tutorial.htm
    Topic is closed.
    www.edelhausrottweilers.com
