Thread: Dome lights
Showing results 1 to 7 of 7
    Mikenificent
    Dome lights
    I heard that they dont normally sell the blue dome lights for the galant, but i would like to know if someone knows how to wire a different type of blue bulb to the dome lights. thank you
    Baltimore, MD
    2,848
    You can actually wire LED's in there or you can modify the existing bulbs that are available to add the little hook on each end, or you can use Gel caps to change the color of the bulb. Those are the only options at this point.
    Chip
    (Paint Code: Porsche LC9Z)
    Quote Originally Posted by Fishboy55
    i did the gel mod and it comes out a green/ blue color... id say it matches my indiglow gauges in the second or third green color..
    Diego
    monosolodoc
    Dome lights
    Gel caps? The protective coating around medicine? HUH?
    Re: Dome lights
    Quote Originally Posted by monosolodoc
    gel caps=colored bulb condoms
    Re: Dome lights
    condoms!! hahahahahah..... well go to autozone and such and u can get them there.. even walmart has em!! isaw them the other ady....
    Diego
    not sure about the 8g's but a lot of 7g ppl are dying their domelights.
