Thread: MESH MESH MESH...Blah!
Showing results 1 to 7 of 7
    Skipp
    ok, i have seen alot of topics about mesh, and people askin how to install it. After reading all the reply's, I never acctually saw someone answer the initial question of installing! Since it's 6:30 in the morn, and I have the sudden urge to do somthing productive, I'm going to go get mesh. So now I'm askin...PLEASE explain how you put your mesh on your 8G...in detail, as if you were speakin to a retard (not the sharpest tool in the shed when it comes to instructions)
    Thnx
    99-01 or 02-03??
    Skipp
    99'
    Skipp
    Is your PS2 just sitting in the glove box, or is mounted somehow?
    aigth u got ur car... tgake out ur grille.. u can stick them mesh down through there.... theres u just work it down!! its pretty simple!
    Diego
    where did u want the mesh? i've seen it in many places
    blakstarz73
    You can go to my cardomain page and look at mines. I had some do it for me, basically for the top they just cut out the "teeth" part and used epoxy to hold the mesh in (go it from Home Depot)
    http://www.cardomain.com/id/blakstarz73
