Thread: Problem With Turn Signal
Showing results 1 to 9 of 9
    One of my front turn signals blinks hella fast for some reason and the other one blinks normal. What's the problem?
    check the bulb it looks like its about to or is blown out possibly.
    <div class='quotetop'>QUOTE(pinoyesv6)</div><div class='quotemain'>check the bulb it looks like its about to or is blown out possibly.</div>
    Actually they are brand new hyperwhites by Eurolite
    <div class='quotetop'>QUOTE(mystik)</div><div class='quotemain'><div class='quotetop'>QUOTE(pinoyesv6)</div><div class='quotemain'>check the bulb it looks like its about to or is blown out possibly.</div>
    Actually they are brand new hyperwhites by Eurolite</div>
    switch em around...tell me what happens
    I've done it a few times already....doesn't really help
    One minute they are operating normally then all of sudden it's blinking fast....never happened before I took out the orange bulbs
    <div class='quotetop'>QUOTE(mystik)</div><div class='quotemain'>I've done it a few times already....doesn't really help
    One minute they are operating normally then all of sudden it's blinking fast....never happened before I took out the orange bulbs</div>
    does that one specific bulb blink fast or is it the side. this can help to determine where ur problem is.
    it's just the side (the left turn signal)
    Is the bulb loose in the socket? Not making solid contact with the two contacts at the bottom of the socket would cause that. As well as a burned out bulb. Check if its loose.
    <div class='quotetop'>QUOTE(RedGalant2k1)</div><div class='quotemain'>Is the bulb loose in the socket? Â*Not making solid contact with the two contacts at the bottom of the socket would cause that. Â*As well as a burned out bulb. Â*Check if its loose.</div>
    Yeah I think that's the problem. The left turn signal socket is much looser than the right one
