pep Boys, Autozone, Advance Auto Parts all should carry Caliper paint. As a backup, you can also use high temperature engine paint. Just make sure it's at least the 900 degree stuff or you'll be repainting more often.
What local store can I find high temp brake caliper/rotor hat spray paint? preferbly in a light metallic blue. All I've seen is ugly colors that look so cheap. :puzzled1:
Chip
(Paint Code: Porsche LC9Z)
i've gone down all the way with 500 degree paint. just make sure you do a really good prep job with it and apply it with thin coats and you shouldn't run into any problems.
