Thread: What is my car???
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 57
    speedrich
    What is my car???
    :shock:
    I just purchased a top shape eagle 2000 GTX 1989 and I wonder what would the model be in the original mitsubishi line?!!!
    It has a 2.0 liter DOHC engine
    5 speed manual tranny
    Front wheel drive
    4 discs brakes
    adjustable suspension
    adjustable power steering
    power windows
    power door locks
    cruise control
    sound system w/ equalyser
    thank you for helping me to know my car!
    I'm new in the world of mitsubishi and I'm starting to like it pretty much!!!!
    Godspell
    Eclipse?
    speedrich
    No!!
    I know it is a Galant...but what I don't know is it's model!!
    Thank you though!
    speedrich
    Come on guys!!!!
    Is this The Galant Center?
    Just kidding!!
    Galant GK1
    im not positive what the exact model is but it is definatley a galant just under the Eagle name. Someone on here will kno. I own a 93 so im not to keen on those models.
    [FIN]Teme
    That would be same model as GALANT GTi,
    but is the adujstable suspension afterwards installed ?
    , normally adjustable suspension is only in 4x4 dynamic model.
    ConceptSleeper
    GTi
    [FIN]Teme
    <div class='quotetop'>QUOTE(ConceptSleeper)</div><div class='quotemain'>GTi</div>
    Didn't i just write that ?... :shock:
    ConceptSleeper
    HOLY SHIT your smart :shock:
    you sounded unassured so i reassured!!
    [FIN]Teme
    it's all good
    speedrich
    Thank you so much guys!!!!
    You're the top of the line!!
    now...let me modd that bitch!! :twisted:
    speedrich
    <div class='quotetop'>QUOTE([FIN)</div><div class='quotemain'>Teme]That would be same model as GALANT GTi, Â*
    but is the adujstable suspension afterwards installed ? Â*
    , normally adjustable suspension is only in 4x4 dynamic model.</div>
    I'm sure that it was there when it was new....because it seems to be quite a complexe system to install...and there was just one owner before me.
    ConceptSleeper
    any pics?
    J apmetal
    They only did the ECS/adjustable suspension [electrically controlled, anything else is aftermarket] on the 4WD models, I'm sure. If you look at the fuse boxes by the battery in the engine bay there arte spaces there marked for ECS relays - if these relays are not there, you dont have factory-installed adjustable suspension.
    If you pass the "ECS Engine Bay Challenge" I suggest getting down & dirty and actually physically checking whether you have 4WD, because you're in for a suprise !
    [FIN]Teme
    "They only did the ECS/adjustable suspension [electrically controlled, anything else is aftermarket] on the 4WD models, "
    yeah, i think so too...
    ConceptSleeper
    Quote Originally Posted by J apmetal
    Hmm...an echo??????
    J apmetal
    NO; a second opinion
    speedrich
    I have other questions!!
    Is an eagle Talon the same as a mitsubishi Eclipse?
    Is the suspension of my Galant the same as an Eclipse of the same year?
    Thank you very much guys!
    I'm just learning!! :oops:
    Godspell
    Ya except for tags and some of the body
    speedrich
    Actually, I just looked where you said to ( on the fuse box and in the fuse box) and there is the marks for ECS relays and the relays are still there!!
    What I think is that Eagle just made a different combination Galant....but I can assure you that the ECS is factory installed. :shock:
