Well, I believe it's common knowledge around here that the Eclipse suspension components would react differently on a Galant due to weight differences, but only if you are using a 4cyl. Eclipse product on a V6 Galant or vice versa. If you are going with a V6 Eclipse product on a V6 Galant, the weight difference is like 50 lbs or so. The Eclipse can gain 50 lbs easily just by adding a few subs in the trunk. So, if that's a problem, then Tein should tell people not to add weight to their cars or their products won't work right.
