Thread: cross and sloted drilled rotors
Showing results 1 to 3 of 3
    GFORCE99
    rotors for the 2000 eclipes fit our 99 galants?
    who has rotors that are from a 2000 eclipes on there 99 galant?
    the rotors from the 3g eclipse, front and rear will fit the 8g Galant. if tyou want to use the big brake upgrades for the eclipse, make sure that u have at least 17" wheels since teh eclipse comes stcok with 17's. but for regular sized rotors, ur stock sized wheels should be good
    GFORCE99
    thanks.
