the MAS, stock ECU and injectors should be able to handle the load of increased airflow from a CAI. you should only run lean on forced induction w/o remapping the fuel curve and adding in a more robust fuel delivery system.
With a cai installed will the car run too lean with any gas other than 91? Has anybody had problems with that?
My car doesn't run lean...and us Calis are notorious for running rich.
