i've never owned a set of coilovers, but from what i understand, the ride with the CO's compared to a good spring shock setup is not even close...
unless you go with the high end stuff... JIC makes a kit that should fit the Galant, but you're looking at $2000 for it, and it has more adjustments than you'll ever need...
I'll stick with my springs... the only reward i see from CO's is the fact you can slam the car if you are in the mood, and raise it back up for normal driving... but you better have some 2x4's ready to drive up on when you want to get under it to raise it again...
