i believe the fogs are h3
if the headlights came with the h1 and h4 harness then u can rewire the stock wiring to them, if not then ull need to go buy a harness or two. make sure you grind down the bumper rests so the lights do not rest or touch them at all.
dont forget that now your turn signal harness will fit in ur signals so u can just extend the wires and plug it into the corner
