Since the JDM and US taillights are the same size, shape and bolt pattern, putting in the taillights are not a problem. They are put in just the same was as you would US Spec taillights. Since there is a different number of bulbs between the JDM and US spec taillights, another bulb and socket need to be added to the US spec wiring harness.
* Enlarge the holes in the back of the JDM taillights to accept the larger US Spec Bulbs.
* Purchase an amber single filament bulb and socket.
* Ground this new socket with the common ground of the wiring harness.
* Reroute the positive signal light lead to the new socket with amber bulb.
* Tap the brake positive lead to the second double filament socket and bulb.
I nor anyone at The Galant Center Shall Be Responsible Modifications to Your Vehicle. Use this page at your own risk.
