Thread: CLEAR CORNERS (easy instructions with pix)
Page 5 of 7 FirstFirst 1234567 LastLast
Showing results 81 to 100 of 126
  1. #81
    fastmgalant97
    will clear corners work on a 7g
  2. #82
    Jackfrost770
    Re: legal?
    <div class='quotetop'>QUOTE(SLS2000)</div><div class='quotemain'>Update. Â*
    LS 2000
    Cleared lenses. I almost got away with not having to take the headlights out. Unfortunately three small pieces fell towards the front of the headlights and Im now forced to take them out and shake them out. Â*
    Tutorial works great with Prybar, Thin bent flat screwdriver, Bent butter knife and Home depot pick set. Ive used them all.</div>
    I need my butter knives for eating (lol) so I just took my girls hair dryer and heated the edges and pulled the light apart at the corner and just let the yellow thingy fall out.
  3. #83
    So I plan on going with the heating method in a few days. My main concern is putting them back together. Is the original glue gonna hold again, or do I need to re-glue it completely?
    Also, Im debating on painting the housing flat black...
    Should I, shouldn't I?
  4. #84
    04-13-2005
    Schaumburg, IL
    1,455
    Quote Originally Posted by CHICAGO_ONE
    noo
    use prybar very easy no mess
  5. #85
    Quote Originally Posted by fastmgalant97
    for the 7g you have to open up the housings and remove the reflector that way. if you do a search im sure you can find a couple picture tutorials.
  6. #86
    yo i have a 2003 g and i did the left side its just the right side headlight that just doesnt want to come out...i took all 4 bolts out and it still doesnt budge....wat should i do?
  7. #87
    keep on working on it and you may want to put some pressure on the bumper in front of the headlight to make the sliding out easier. I will eventually let go if you keep on wiggleing it .
    8G 4 life!
    Mods: CAI,Grounding wires, CCorners, Shaved, 3G STB. AGX/Teins, Addco bar, OZ F1 wheels And well maintained : )
  8. #88
    alrite thanks man....ill try 2morrow morning
  9. #89
    01-10-2008
    Oceanside/Camp Pendleton, CA
    1,848
    Re: 8G: CLEAR CORNERS (easy instructions with pix)
    Quote Originally Posted by clone2020
    Here is the tool I used. You can get these from almost any hardware store for around $5. If you are unable to get one of your own, I will ship it to your door for $10.
    Bought this exact tool at lowe's today for $3.98+tax
  10. #90
    01-10-2008
    1,848
  11. #91
    What kind bulbs do you have in your heads/fogs?
    Black '02 2.4L ES ~ TGCLI
  12. #92
    he has 8000k (pretty sure its that temp from the looks of it) h.i.d.'s in his heads/fogs
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  13. #93
    Quote Originally Posted by Ivory8g View Post
    Werd, thanks.
  14. #94
    hmm.. does this work on jdm's the same way?
    i might do it if its easy..
  15. #95
    on the 1pc jdm headlight, you have to open them up to remove the reflector.
  16. #96
    Quote Originally Posted by pinoyesv6 View Post
    damn... i really like the all black and silver look.
    i might bake them i guess... what kind of sealant do you use on them when you put them back together?
  17. #97
    answer please. lol
  18. #98
    i thought you could just reheat them and use the same glue?
  19. #99
    pretty sure u can reheat and use the same glue if you do it right, but i could be wrong, i havent done it
  20. #100
    07-19-2007
    Connecticut
    3,994
    have silicone there JUST incase teh clue doesnt reseal
Tags for this Thread
