Originally Posted by
Reelax
i think they are reffering to the bolt pattern. our rims are 5x114.3mm or 5x"4 and a 1/2 inches". does the rim have 5 holes or 10? if it has 10 the other 5 not used may be the correct bolt pattern... 2 other numbers you have to find out are what the wheel width is (stay less than 8" to be safe, 8.5" may fit w/ some fender rolling) and the offset (stay as close to +46mm as possible) also correct tire would be 215/45zr17 or 225/40zr17 (i prefer the second although it is slightly taller than stock).
i think you meant the 1st one is taller than stock...
i wouldn't go buying some rims off a guy unless you have all the info you need... width, offset, and bolt pattern...
