Thread: Where in the engine bay can I change the revs? (1994 HJ JDM)
Showing results 1 to 8 of 8
    BlackBeauty
    Hi all,
    I have a 1994 HJ (JDM) - can anyone tell me where exactly in the engine bay I can change my resting revs? At the moment, it's revving a bit too high...
    Thanks in advance!
    BB.
    12-17-2002
    Sherman Oaks, California
    4,304
    well, i have a 94ES USDM, and ur car looks completely different. but on my car, at the throttle body, the spring loaded wheel that opens the throttle has a screw that you adjust to very very slightly open or close the TB.
    http://socallifestyle.com/
    1994 Galant GS 5spd
    BlackBeauty
    Thanks peanotation I'll check it out.
    BTW nice car - is that the 4 cyl or 6 cyl?
    12-17-2002
    4,304
    <div class='quotetop'>QUOTE(BlackBeauty)</div><div class='quotemain'>Thanks peanotation Â*I'll check it out.
    BTW nice car - is that the 4 cyl or 6 cyl?</div>
    4cyl...
    1994 Galant GS 5spd
    BlackBeauty
    okies then mine's a 6 cyl so i'll follow your directions and have snoop around for it on the weekend - hopefully it's in the same place!
    thanks again for the speedy reply peanotation!
    Member
    01-18-2003
    Brisbane, Australia
    132
    black beauty i was told that the idle of the HJ is auto... there's a screw just after the black hose that connects to the throttle body... but a mechanic told me that its only for air flow...
    BlackBeauty
    Hi Naughtika
    Since peanotation's reply, I've actually gone and tried it.
    The screw on the throttle does in fact adjust the idle....I've done it. However, there may be some default settings for idle also....
    BlackBeauty
    Me again....an update
    Okay, just an update:
    I've been fiddling with it and on a number of ocassions found the 'optimal' level to have the idle tuned to.
    One problem - it keeps losing the tuning!
    After driving it around for a day or two, it all goes back to normal and starts running like a slug again. It's like the screw keeps coming loose or something?
    Also, when the revs drop below 2000rpm and i'm braking it tends to 'chug' - like a manual does when it's in the wrong gear (when the current gear is too high).
    Any ideas?
