Thread: HELP! gotta remove crappy tint!!!
Showing results 1 to 6 of 6
    G-Lant
    what would the best way to remove crappy tint!
    Thanks
    Umm..get ammonia spray your windows with it and let it bake in the sun for 3-4 hours...the longer you let it bake in the sun the easier it will be to get off.
    Marcin P.
    ANSA Exhaust
    Apex Springs
    KYB AGX struts all the way around
    (slowly working on more things)
    Speed doesnt need beauty ~ Me
    and then if there is any glue residue, get a very fine steel wool and scrub it out using some windex and polish with a terry cloth towel. as for the rear window, be very careful, u don't want to damage anything. chances are u'll damage ur defroster lines...its gonna be hard to not damage them
    MitsuMan
    just make sure u dont scratch the glass with the steel wool
    Quote Originally Posted by MitsuMan
    actually really fine steel wool will scratch ur glass...a bad scratch no? actually its kinda like wet sanding....it will make ur glass shinier my sanding away some of the microscopic scratches on it
    G-Lant
    thanks for the tips. hopefully i won't f-up the defrost lines.
