Originally Posted by yofadahead
ive seen people shave the whole thing off...but i dunno bout keylocks... ever thought of touch painting it?
does anyone know how to shave the key locks off? i think my car would look cool with them off.
i'm talking about the ones on the outside doors.
Diego
bondo, or maybe take your handles off, sand, bondo, sand prime, paint, etc.
-Chris
what do you mean? arnt the rear handles the same as the front?Originally Posted by Messiah [Reborn
i take it you mean shaved door handles?
(yes the front door is slightly open)
Cali: Sig 3/28/2011
what happens when ur remote key unlock doens't workOriginally Posted by verywhite01
Originally Posted by peanotation
you open the front door and unlock it from there..
AkA K h O p A r I.
I Am back BitcheZzZ
but how do you open the doors if there arn't any key holes to put your key into.Originally Posted by K h O p A r I
some people put a popper in a location in the car, somewhere hidden like the inside wheel well under the car. if you don put one in then if you car is out of battery then you will need to jimmy the car.
keep in mind that u dont have to get just the body work done, ur gonna have to get all the different mechanisms that would pop the door out ajar just enough so u can open it
<div class='quotetop'>QUOTE(Sowndwayv)</div><div class='quotemain'>keep in mind that u dont have to get just the body work done, ur gonna have to get all the different mechanisms that would pop the door out ajar just enough so u can open it</div>
Yeah I realize that, im just trying to get an estimate on the body work alone for now.
<div class='quotetop'>QUOTE(Cali)</div><div class='quotemain'>i take it you mean shaved door handles?
(yes the front door is slightly open)</div>
:shock: there's a good anti theft idea.
-Pedro
<div class='quotetop'>QUOTE(Kalamidad)</div><div class='quotemain'>
:shock: there's a good anti theft idea.</div>
i was thinking about that, and as was mentioned earlier, there should be a manual open switch installed somewhere installed in case something goes wrong. my question is..what would stop just anyone from opening ur door if they knew where ur "secret" release switch was?
would it be possible to mount that switch in the trunk somewhere? since there would still be a keyhole there?
there's another way to get in....no electrical current is needed it's all manual....and no im not gonna share it with people on the board....any good body shop person will know what to do. i've used it a couple times when my battery had died out on me.
Cali: Sig 3/28/2011
iv been wanting to do this to my G. Me and my friend did it on his 2G eclipse but its still primered so doing the shaved handles i can do. my question is if i do this to my G will the whole door need to be painted and two if only just a square around the door handle needs to be painted about how much will that cost and will the paint match the stock silver paint with the sparkles in it. dont want to how do i say this.............i know "i dont want to fix it if its not broken" if you guys know what i mean.
<div class='quotetop'>QUOTE(nastyrican2g)</div><div class='quotemain'><div class='quotetop'>QUOTE(Messiah [Reborn)</div><div class='quotemain'>]why not buy rear door handle and put them in front</div>
what do you mean? arnt the rear handles the same as the front?</div>
Rear door handle does not fits on front door, I tried it and the rear is flatter than front and leaves a nasty gap...
'00 Patriot Red GTZ --> JDM'ed... 5 Speed... ...
damn. that's what i was going to do. i don't know how what to do about the keylocks then. i was going to take my door apart any way, so if i find some way or some different handle that fits, i'll post it.
