Thread: does anybody know how to do this?
Showing results 1 to 4 of 4
    Faction
    how do i make my own MAS adapter? im on a budget, only enough money for a cone filter
    go down to the plubing store. they make end caps for pvc pipe you can use that. just cut a hole in the middle, drill 4 holes for the bolts and you're good to go. some of the end caps are perforated so you don't have to cut a hole but it does cause a slight restriction.
    but if you're really serious, just get one off of ebay. u can get one with a filter for like 15 dollars.
    bam462
    hey pin we gonna change your name to mcgiver
    get the ebay one, its cheap and effective... for the price of just a cone filter you get a filter and adapter.
    its what i have...its good times.
    -Travis
    My Car
