Thread: 1/4 Mile times for the I4 (Stock or Modded)
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 43
    PoisonPancakes
    Hey people just interest what are your 1/4 miles times for your I4s? If you have mods list them.
    Senior TGC Member
    2,175
    I'll post my old 4 banger, I no longer have it.
    Fed spec, no mods: 17.7 seconds
    18.2 Stock @ 76mph (NOTE: Stock PSI all around) @ 80 Degrees
    17.7 CAI, Muffler @ 79mph. (NOTE: 27psi up front and 36psi in rear) @ 70-75 Degrees.
    16.8 @85 I believe
    Cai-custom w/ram air
    gutted precat w/3' exhaust obx muffler
    aem cam gear & pulley
    Obx Fuel pressure Regulator
    Walboro 255 Fuel Pump
    think thats all
    oh yea with 200+lbs of sound equipment in the trunk lol
    05-14-2003
    Southern California
    1,404
    Quote Originally Posted by Mante
    16.8 @85 I believe
    think thats all
    Damn not bad at all!
    Supernova
    Quote Originally Posted by RedGalant2k1
    Fed or cali spec? Same question for you Mante.
    yea I got a damn cali spec...well had anywayz
    09-22-2002
    Kissimmee, FL
    1,495
    13.9@105mph Bithlo Raceway Orlando, FL (on the bottle)
    Race Built All-Motor, 2 many mods 2 list..
    11.5@ 115mph ( 16psi 16g turbo )
    11.5 damn thats quick what kind of pistons do you have i dont know which kind to use JE or wiseco and i was thinking about 8:1 compression im running a 14b so boost comes on pretty quick so i dont have to worry to much about turbo lag... also if you dont mind what kind of electronics are you using?
    "run your car, not your mouth"
    http://www.norcal-performance.com
    09-22-2002
    Kissimmee, FL
    1,495
    Quote Originally Posted by Whips_n_chains408
    JE low comp 8:5.1, with a 20% overbore.. You can use the wiseco pistons since they are a direct drop in, no need to bore it out to fit. Electronics are pretty basic, HKS turbo timer, S-AFC, EGT guage, and Tranny Temp guage.. The only reason i have the Tranny Temp guage is because the 5spd has only been in the car for like 3months and i wanted to keep track of how much heat was being produced from it either on the bottle or off of boost..
    so your runnin nitrous too? damn i still cant get over that 11.5 on 16psi hopefully i'll be there in the next couple of months
    what's an I4? i remeber having too chose between a 4 cylinder and a 6 cylinder G at the dealer....never heard about the I4
    I4 stands for inline four cylinder cuz they dont call em v4's lol
    09-22-2002
    Kissimmee, FL
    1,495
    this was like a 4-5 months ago, before i did the engine rebuild again.. right now im using a set of JE high comp 11:5.1, and crower rods.. Trying to do it NA.. Thinkin about trying out for the Xbox tour next year though..
    09-22-2002
    Kissimmee, FL
    1,495
    thats tyte but whats the x-box tour
    RadRICH - TGC Founder BGR's Avatar
    12-09-1999
    FLORIN - Sacramento, CA
    1,996
    Only on motorcycles. Hmm, at least that's what I remember a long time ago. I think the other name is a V-Twin.
    09-22-2002
    Kissimmee, FL
    1,495
    Its a huge race event where you go out run brackets or heads up against other people in your class, if your lucky you get a sponsor and run pro.
    oh damn thats hella tyte when does that happen?
    Quote Originally Posted by Supernova
    2001 Cali Spec.
