Nevermind, I found it.
Here it is if anyone is interested
http://www.geocities.com/bracecraig/maxima...max_rewire.html
Could someone post the tutorial on how to rewire the turn signals so that they give off the maximum light?
Check this thread http://www.tgc-forums.com/phpBB2/viewtopic...ighlight=reelax
There should be 3 scanned pages of a tutorial reelax did on it once, and you can buy the spdt relays from crutchfield.com
the tutorial said the rewire would make it as bright as the headlights and you won't see it blink...but it still blinks right? so we don't really need the relay switch right?
Thanks
The relay is what makes you able to see it blink, the relay turns off the bright filament when power goes to the dim one, so basically after the mod when you signal the dim and bright take turns blinking on and off, and when your not signaling, just the bright is on. Its worth getting the relays, they are only like $8 each or something, its a great looking mod for less than $20 in parts.Originally Posted by wwangster86
If you do it without the relay, the bright will always be on, the dim will still blink when you signal, but you wont be able to see if over the light from the bright filament always staying on.
just an FYI, that maxima rewire won't work as well since the way they show to wire, you will completely lose the signal in the corner. the maximas have a seperate signal / marker, so it's ok for them to lose their signal in the corner... they still have a marker to blink. the 8Gs only front signal is the corner.Originally Posted by mystik
METAL POWER 5000K H7 HID (old set), POLARG 1157 hiper white bright-wired, NOKYA 893 hyper white fog.
Reelax can you post the tutorial then?
Cool. I currently have these archive here: https://thegalantcenter2.com/tutorials/8G_blinkermod/
Could someone who has done the rewire post a picture so that I can see where they placed the relay
