Clearing Headlight corners
I came across the forum about making your headlights clear. So which way out of all the ways stated is the easiest without damaging it.
http://f1.pg.briefcase.yahoo.com/bc/wiredt...chments&.view=l
your asking for opinions, and we all know how that is.
I feel, my way was very easy provided you have a hair dryer and patience and an old flathead.
Ill do this
Ill try it your way on one side and someone elses on the other and return for the final results on whos way is better or easier. I guess I got a project this weekend. Thanks!
Member
well, i can tell you that the quickest way (once you get the hang of it) is the old fashioned "take-out-housing-pry-plate-cut-it" technique. Now this can be easy or hard, depending on ur skill and ambedexterity (cant spell).
that way took me 15 min one one side, when i finally noticed if you do it right, you dont have to push hard, and it took me less than 1 min on the other side...
