your not going anywhere with $2000.00, atleast not turbo or sds. ebst bet would be ripp mods sds system, low comp pistons, cam shafts, etc... all parts would cost you around $6000.00 (for sds, cams, pistons, fmic, etc.) you would be able to boost a little more since you did internals as well. install for everything between $1200-$2500 (depending on the shop) you could easily get 260whp with the sds and internals. you dont need to do internals if your gonna leave the compression at what ripp has it set at. i think its between 6 and 8 psi. this setup would probably give you around 220whp give or take a bit.
