Thread: MAS Question
Showing results 1 to 8 of 8
    MAS Question
    ok, ok ,ok........
    i got a dreamspeed intake and i love it. but i had a thought today in math class. to take off that black plastic screen on the mas for a little more air flow. so my question is, is that going to hurt anything or mess with emsions.
    thanxs guys
    2002 Silver Galant
    "If a man yells in the Woods, But there is no women around to hear him, Is he still wrong?"
    A question that has plauged man for ages.
    i'm assuming you mean the honeycomb? forget it. that is a very bad idea. that honeycomb smooths the vortecies of the airflow for the sensor element to get a proper reading. removing the honey comb will cause all kinds of troubles from rough idle to inconsistent throttle response and will probably throw SES codes as well.
    Senior TGC Member
    07-31-2002
    Sugar Land, Texas, United States
    2,175
    If you're unlucky it may throw a code because it might have trouble metering proper air/fuel. I think removing the honeycomb is actually worse for performance though, because it either straightens out the airflow or makes for turbulence, I forget which it is but our cars need one of them. Sorry if I confused you any :?
    thankx
    thanks you guys... thats y i asked so now i no.... leave it there
    2002 Silver Galant
    DONT touch it.
    it is NOT a restriction, and it WILL cause problems if you remove it.
    VIO
    i tried removing it a couple of months ago as i was curious to see exactly what would happen. at first the car runs fine but after about 20 minutes of driving the idle starts to fluctuate and the car will eventually die. i put it right back on and it ran fine. bottom line, don't do it.
    i hate this damn class
    this is cool that so many people are willing to help me. like i said i do understand some things about cars, but things like that im clueless,
    THANKS
    2002 Silver Galant
    it straightens out the airflow heading into your engine. This is not necessarily there for power, but also so the MAF can read the amount of air flowing into your engine. If you mess with it, the ECU will have to guess at how much fuel to inject, and your car will idle rough, die, and have huige power losses.
