Thread: check connector
Showing results 1 to 2 of 2
    blackcar28
    check connector
    does the fuel pump check connector override the mpi relay :?
    ken inn
    if the ign is OFF, the check pump connector will run the pump. i use it to set my static pressure, i dont know if it will override it when the ign is on. you may blow some fuses, or pop a relay. all you do is jump the connector to power.
