i got coilovers on my ride, and its LOW. i have 17x7s with 215/40/R17s on the front, and the top of the tire is dead on even with the fender. here's an idea of how low i am, click my www for a shitload more.
if i were to get coilovers, how low can i drop my car. i mean, how close can i get to wheel tuckin with out rubbin. cus i dont like the way the rear sits on this car. i wanna at least even it up wit the front. right now i got a 1.5 drop in the front and a 1 in the back. i want lower!
how much of a drop did u do in the back
errr....2". the back end of both 7Gs and 8Gs are pretty decent. you can always go for that tucked look, but you'll never clear a speed bump because i barely can. i dropped the front 3.5". my drain pain is literally 2 inches off the groundOriginally Posted by nelly123
If you have 17s you can go pretty low without rubbing, when I had my coilover setup and 17s I dropped it 3 inches (maybe a bit more) all the way around. The ride was crappy but it was slammed.
If you have 18s you'll rub over bumps and dips with the Eibach pro-kit drop, not sure about 17s.
<div class='quotetop'>QUOTE(brandon)</div><div class='quotemain'>If you have 17s you can go pretty low without rubbing, when I had my coilover setup and 17s I dropped it 3 inches (maybe a bit more) all the way around. The ride was crappy but it was slammed.
If you have 18s you'll rub over bumps and dips with the Eibach pro-kit drop, not sure about 17s.</div>
thats true, the lower you go, the shittier the ride
by my god....the handling.....
i thouht the closer u were to the ground the better control, but big turns are probably pain
I lowered my Galant on 18's with 215/35's . . . . . . . 3.5 inches, Like I didn't give a F@$%. . . . .
