Thread: IAT sensor location
Showing results 1 to 6 of 6
    jlipenta
    IAT sensor location
    Where is the IAT sensor located on the 2.4l engine?
    inside of the airflow meter. along with the barometric pressure sensor.
    DONT tamper with it (if thats what your intention is).
    jlipenta
    I have a performance mod (a resistor) that is supposed to go on the harness before the sensor. Do you have any info as to whether this works? It's supposed to fool the system into thinking it's colder outside and increase performance.
    <div class='quotetop'>QUOTE(jlipenta)</div><div class='quotemain'>I have a performance mod (a resistor) that is supposed to go on the harness before the sensor. Do you have any info as to whether this works? It's supposed to fool the system into thinking it's colder outside and increase performance.</div>
    yeah, i have info..
    its a totally useless mod that will probably cause drivability problems and poor milage, whilst not gaining you a single HP.
    yep fishboy track tested that mod and it is worthless.
    jlipenta
    Thanks.
