Taillight fuse keeps blowing.....
my interior lights where my odometer is, went out...then i noticed my taillights were also out (at 12:00 am), i made it hame and checked my fuse, sure enough it was blown...i changed it and everything was fine...then it blew after i had the lights on for just minutes ... i figured the fuse was bad changed it again(and again and again)..same problem, then today my fans that blow air and a/c into the car quit working...What's going on!!? no taillights-no a/c (in south FL) HELP ME!!!
Oh...if it helps i have a 95 and it's the fuse under the hood not the one under the dash...help !!! (fingers crossed)
have you done anything to your car recently dealing with electrical stuff..
just ask cuz when i took my car to circuit city to have my head unit installed they did something to where my fuses kept blowing mainly my tailights
yep.. Ill bet you have an aftermarket radio, or dash lights, dont you?
that will be the source of the problem.
