Thread: 6g72 Cams....
Showing results 1 to 2 of 2
    00GTZ00
    6g72 Cams....
    Is anyone here running anaftermarket cams set up? RPW or otherwise?
    What are the specs of your cam? lift? duration? etc.etc.
    TWISTED II
    well i would be running the stage 2 turbo cams if david would stop sending me the wrong ones. i'm waiting on my 4th set of cams now. car should have been running over a month ago if it wasn't for this little mix up. i'm not sure of the specs though.
