Thread: Intake question
Showing results 1 to 5 of 5
    <div class='quotetop'>QUOTE(MrDomu)</div><div class='quotemain'>Is the TB mod is see posted a bypass of the coolent. If so, I'm in CT and it gets cold here, I don't think I would want to perform this mod. Any thoughts?</div>
    you can peform this mod but, i would revert everything to stock when it starts to get cold
    J. T. Z.
    All the mod requires is removing the hose, so if you did it you could always just plug it back in before it gets cold.
    Supernova
    Sooo, all Galants are recommended to use premium gas?
    <div class='quotetop'>QUOTE(Supernova)</div><div class='quotemain'>Sooo, all Galants are recommended to use premium gas?</div>
    the v6...go premium, with the i4 you could stay with regular....
    MrDomu
    JTZ- I looked at the hoses for the mod on the TB, it would certainly be very easy to bypass/connect when in hot/cold weather.
    When in bypass mode, just let any coolant drain out or should you cap it off(on the TB). I would think that if I were to let it drain out, then it might get crusty in the channel around the TB.
