Thread: mitsu's achilles heel
Showing results 1 to 20 of 22
    BlueESV6
    It occurs to me that I've read various posts by people who have dynoed their old/new exhaust, headers, intake, etc... . It seems none of these changes to the engine's systems have posted much HP gains (2-4 hp).
    Others who have done major mods like nitrious/ supercharger or turbo have gained signifcantly more power... (obviously)
    My question is this... if the "small" mods did not make big HP gains on our cars then what CAN make a big difference? Other manufacturers do have larger gains with things like aftermarket intakes, etc.... (Injen/AEM on acura etc..)
    I think one possible reason for the lack of gains from mods is that mitsu's R&D has already gotten the most that the system can deliver. An example is the intake... the tube is about the same diameter as an aftermarket, it just is not as nice looking. But the functionality is already there (as posted by the lack of HP gain).
    So what smaller mods will give a decent gain? Where is the mitsu's achilles heel (in the car's engineering) :?:
    Good, no damn good question. The only avenue I can think of is trying an custom intake manifold then again thats wishing on stars. Im clueless on what to try next.
    has anyone ever port polished their galant?
    got me
    00GTZ00
    The problem with the cars are the cams. That is what is limiting the cars if you replace them you will see much better gains with the CAI and the full exaust. But beause they put in such a crappy cam our cars are limited as to what they can do N/A....
    you can also replace drive train componenets to improve efficiency of the tranny. try to get the drive train loss down to around 13-15% (and you will gain some free hp)
    cdaw2001ES
    My take on this is, all the smaller mods that yeild little to no gain to a stock platform, exponetially help get a larger gain from a $$$ boost type mod. Otherwise - Our cars are pretty much like every other mid level ($15-$21K) 4 door in that respect. Your not going to get major gains, unless you do major mods. And even then you still hit a wall - that requires MAJOR $$$ to overcome. Like all the parts a family sedan has that a race car dosnt and viceversa.
    Fastses Mitsu I know of is using a (FULLY Built) 4g63 mated to a chevy transmission- Ford rear, on a custom tube frame chassis, with a replica talon body. high 7 1/4's last I heard.
    09-22-2002
    Kissimmee, FL
    1,495
    I have the same concensous, not really sure what else to do. I did everything possible for the first motor, and i didnt really see any real power until i but the bottle on it. I think mitsu's engineering is just fine, but i think they actually squeezed all the power out of the motor that they could, so basic bolt on-s dont make a huge difference. hence you look at the honda motor and they bolt on a intake and they got 10whp to play with. I dont really think its the cam set-up myself. I think the cam timing is pretty good if not better than what most cars come out stock with. I think Mante bought an aftermarket set and actually got +6whp from them, which is pretty good. I wish the USDM version of our cars had some kinda valve timing like MIVEC, that would kick ass..
    i agree. if we had something to combat toyota's VVT-i or hondas VTEC or i-VTEC on our galants, itd be great effect. i wish we were DOHC too.
    then again, you can engine swap for a 3kGT VR-4 6G72TT...
    it all comes down to $$$
    05-14-2003
    Southern California
    1,404
    Oh I could see it now:
    MIVEC+DOHC+stock internals that are as good as the supras+6 spd sequential gearbox+AWD-1000lbs
    ...Im drooling all over the keyboard.
    TWISTED II
    i dunno, bolt ons like intake and exhaust are not meant to give huge HP gains. nothing you do to your motor unless its forced induction is going to make it have real high HP gains. i have done: bored out the block, rods, pistons, cams, valve springs, cam gears, CAI, headers, exhaust....and i'm prolly gonna be as slow as stock if not slower. those things are to make the motor strong, not to make it fast. cams could give you some gain, but any gain i got from that was lost by the drop in compression. (so any of you I4's wanna race a fully built V6 and win do it now before the TT's, haha) anyway, but yeah, the real power is in the forced induction. and about the port and polish.....i've considered doing it, but the ports on the 6G72 are actually pretty well done. i didn't think it would be needed at the moment.
    00GTZ00
    HeadAche - I am leary about the hondas getting 10 wheel hp from just an intake, you are talking about the 4cyl right? every 4 cyl car that I have seen add an intake has not yealded more that 5 whp on the dyno. Do you have a link to a dyno sheet of this?
    I think that our cars could do 300+ flywheel hp reliably all N/A if it is built from the block up as follows:
    __________________________________________
    Deck the block
    balance the crank
    forged pistons
    bluprinted bearing throughout the block
    High compression cams
    mill the deck of the heads down to gain more comp.
    mulit-angle valve job
    swirl polish and back cut valves
    valve springs
    cams with a bigger lift and more duration
    mill the lower intake to realign with the milled heads
    gasket match the lower intake (extrude and hone)
    gasket match the upperintake to the lower (port and polish)
    bigger throttle body
    gasket match the upperintake to the bigger TB
    CAI
    full length headers
    high flow cat
    true cat back
    Fuel presser reg.
    If people are serious about getting HP they will open up the engine and start replacing parts.
    But ya NO CAI, headers, catback or small mods will change your car into a speed demon!
    as far as the small mods that you can do for relitivly cheap
    CAI
    Headers
    Cat-back
    Alt pully
    fuel pressure reg.
    cam gears ( do they even yeald hp? or are they just lighter weight?)
    bigger TB
    yofadahead
    what engine wouldn't?
    Senior TGC Member
    2,175
    <div class='quotetop'>QUOTE(00GTZ00)</div><div class='quotemain'>HeadAche - I am leary about the hondas getting 10 wheel hp from just an intake, you are talking about the 4cyl right? every 4 cyl car that I have seen add an intake has not yealded more that 5 whp on the dyno. Do you have a link to a dyno sheet of this? Â*
    </div>
    I used to have one. I saw an AEM review by an independent party done on a RSX-S that yielded 7whp average with a best run of 11 whp. I think you're right...our cams suck, and I believe Rippmods touched on the engine block itself though I forget the post.
    00GTZ00
    <div class='quotetop'>QUOTE(yofadahead)</div><div class='quotemain'>what engine wouldn't?</div>
    a 4 cyl
    those mods on a 4 cyl would get you to about 240-250 crank hp
    on a v6 300-320 crank hp
    on a v8 400+
    all est based on "newer" engines.
    But this is just my opnion based on my personal experiance. take it as you will...
    08-04-2003
    NY
    4,344
    Our Motor isnt the best setup but more importantly, our tranny is weak. Think about it our auto tranny loses like 35hp between the crank and the wheels. Im sure if any of you guys ask shane, he has the 5 speed in his car and its a huge difference. I am going to attempt the swap myself in the next few months, along with my DOHC head swap. If your looking to get big gains from intake, exhaust,etc. You gotta setup the motor right. You gotta pick either forced induction or normally aspirated. If your going N/A get some high compression pistons, a cam, underdrivce pulleys, cam gear, and some electronics to advance the ignition timing. You need to make the parts work together to get their full potential. You can have all the mods in the world and still be running the stock ECU timing and your motor will run terrible. There are alot of factors that effect your cars HP and speed. For example, if oyur taking your G out to race somebody, why dont you spend an extra 20 mins and take that HUGE subwoofer box out of your trunk first, should save you a couple hundred pounds. In my opinion the best way to get power from our cars is forced induction, but I can definetly see a N/A galant getting up about 260whp. It's definetly do-able if you do it right.
    99' Galant ES
    4G64/63T
    AEM EMS
    09-22-2002
    Kissimmee, FL
    1,495
    Deck the block
    balance the crank
    forged pistons
    valve springs
    CAI
    full length headers
    high flow cat
    true cat back
    Fuel presser reg.
    If people are serious about getting HP they will open up the engine and start replacing parts. Â*
    CAI
    Headers
    Cat-back
    Alt pully
    fuel pressure reg.
    bigger TB
    _________________________________________</div>
    I saw it in an old issue of Super Street, it was done on a S2000 and then in Honda Tunning on a RSX-s.. If i can find the old issue i will post it..
    00GTZ00
    I guess that the Honda/Acura guys really do have crappy intakes..go figure...
    <div class='quotetop'>QUOTE(ThaTwistedGTZ)</div><div class='quotemain'>i dunno, bolt ons like intake and exhaust are not meant to give huge HP gains. Â*nothing you do to your motor unless its forced induction is going to make it have real high HP gains.</div>
    I hope you mean just in relation to our engines, cuz I know many people with old musclecars that have tons of power and are N/A
    00GTZ00
    <div class='quotetop'>QUOTE(Strahan)</div><div class='quotemain'>I hope you mean just in relation to our engines, cuz I know many people with old musclecars that have tons of power and are N/A </div>
    ya but what size engine do they have? 6.0L 5.7L 6.5? all v8's are moving 2X as much air as our cars that is why they see ~2X better results with bolt ons than we do....
    TWISTED II
    <div class='quotetop'>QUOTE(Strahan)</div><div class='quotemain'><div class='quotetop'>QUOTE(ThaTwistedGTZ)</div><div class='quotemain'>i dunno, bolt ons like intake and exhaust are not meant to give huge HP gains. Â*nothing you do to your motor unless its forced induction is going to make it have real high HP gains.</div>
    umm..."TheGalantCenter" giving information out on galants.....
    stewi: how do you come to the conclusion our motor isn't the best setup? just curious.
