Thread: 4G93 Swap to 4G93 Turbo
Showing results 1 to 3 of 3
    DaMusicGuy
    Hey,
    I currently have a 95 Galant with a 4G93 Engine. Bloody gutless engine, Anyway just wondering if any one has Upgraded this to a Turbo 4G93T and if so whats involved. Will the engine mounts & bell housing fit up sweet ? Is it basicaly same block just with different compression ratio ect ?. I realise I will need the turbo ECU But will I also have to replace the wiring loom also ?
    Cheers
    DMG
    07-20-2003
    Orlando, FL
    3,169
    Most of the Galant owners here are from the U.S. and no US Galant was equipped with a 4g93 (Or any Mitsu car sold here in fact). All I know about these motors are they were in the Orginal Lancer GSR before the EVO series birth. 4G93's have been turbo'ed but details on what they used won't be found here on TGC. You can visit http://sites.ecosse.net/chunky/lancerindex.htm...this guy turbo'ed his 4g93 and produced some decent power from it with 10psi. Hope this helps ya.
    DaMusicGuy
    Hey Dude,
    cheers for the page will give it a good look through..
