The connection for the second O2 sensor is under the drivers side floor board/carpet. Hope that helps.
Is there some special way to take out the second O2 sensor? the one that goes in a hole on the bottom of the car. I cant seem to get the connection off. Some place in the interior to do it from or just pull as hard as i can?
YES I STILL HAVE MY GALANT!!
Its not under the carpet, its inside the center console behind the radio. Remove the side panel by the drivers right foot, and there is a lil gromet on the floor with a connector, unclip the conector and shuve the wire through the gromet. Dont just unclip it and go under need and yank your exhuast off the end of the connecctor is a tight fit in that gromet you have to push it through from up top or ull yank the pins out.
Rob
rIp 97 Galant
starting over.
90 Talon
