Thread: AEM Universal Adjustable Fuel Pressure Regulator
Showing results 1 to 4 of 4
    utlize
    will this work for the on my I4 if not any ideas
    http://www.first-1.com/Merchant2/merchant....Code=AEM-25-302
    Baltimore, MD
    2,848
    Yes, it will fit fine on your I-4. However, it doesn't have an external pressure gauge. So unless you buy one (and it has a third inlet) you'll have no way to know what your fuel pressure is.
    RPW sells the FSE regulator which has an integrated pressure gauge. It's the one I have and it works great. You can also search ebay for fuel pressure regulator and see if you can find one there.
    Chip
    (Paint Code: Porsche LC9Z)
    yea i got mine from ebay for 75 comes with gauge too...
    uhhhh...... Whats a 9g???
    Re: AEM Universal Adjustable Fuel Pressure Regulator
    <div class='quotetop'>QUOTE(utlize)</div><div class='quotemain'>will this work for the on my I4 if not any ideas </div>
    I'm personally using a B&M commandflow with a B&M fuel pressure gauge. They work really nice, look very clean, and I have had no problems with either of them at all. Don't know if they make one for galants, but both gauge and regulator came out to about $90, brand new. The AEM regulator replaces the entire regulator body, which really isn't necessary, for i think about $130. Then you still have to buy the gauge. AEM is good stuff (except for cam gears ), but it is expensive. If you want to save the extra 70-80 dollars get the B&M kit
