Thread: ECU pin outs...
Showing results 1 to 14 of 14
    ECU pin outs...
    Anyoen have a ECU pin out diagram? i need one so i can wire up my SAFC on tuesday. And does pretty much any auto parts store sell the chiltons manual? i know it sucks, but its better than nothing sometimes
    and those of u that are non turbo and have a safc 1, what are your low and high th points?
    Pep boyz should have chiltions, or Autozone. i bought mine from Murrays Auto Store. it was like 22 bucks.
    Does the Chiltons have a ECU pin out diagram?
    brandon
    I was hoping to find this somewhere to...
    None of my local parts stores have the Chilton's... but I did find out that you can order from Carquest if you have one near you. I think it was like $20 or something, includes all Galants from like 90-03 or something.
    Seth, I can probably see if my buddy's Chilton's has the diagram. I'll let you know after I can get in touch with him.
    San Antonio, Tex-Mex
    1,413
    Negative.. Chilton's doesn't have it. But guess who's got the 411? That's right! your buddy Wes
    http://www.clubtgc.org/forum/viewtopic.php...&highlight=safc
    That's about all the info we could gather on the 7g ECU there, hope dat helps bro.
    <-Check it out Maz
    My 7g
    Moosh
    Here is probably the most in depth and greatest diagrams available. It includes the turbo Eclipse also so it is a great help for those going DOHC. Straight from Mitsubishi. Consider it a gift.
    http://mysite.verizon.net/vze7f20i/wiringdiagram.pdf
    brandon
    Sweet, thanks Moosh...
    what's this I see in your sig? You've given up on the Galant for good?
    Moosh
    Yes I have, I'll write a whole story of how hard I tried when ever I get time so you guys realize the extent and sufferring I went through for it. But now its over
    Look what I made! not sure if this applies to 94/95 galants
    1,413
    THAT my friend, is a beautiful thing! :thumbsup:
    <-Check it out Maz
    My 7g
    so she is all wired up! Working and everything, now I have to learn how to use it. Wired it up as above and everything works just dandy. I'll write up a tutorial cause theres more you need to know besides the diagram(not much though hehe)
    brandon
    Sweet Seth, you seriously rock.
    I've had mine sitting for over a week now and haven't installed it.
    Moosh
    Seth failed to mention Rob and I told him how to do it all
    :lauging: you guys helped me with the pinouts and such, i just made the picture and the tutorial
    props to Moosh and JiP who are always there for me when I have a question about anything 8)
