Thread: Anyone with "REAL" dyno number post in here....
Showing results 1 to 14 of 14
    00GTZ00
    I was thinking, because of all the dyno talk in a few threads and some people were wanting to see dyno numbers of our cars, I thought it would be a good idea for everyone that has a dyno sheet to post it here and state what your mods are. Then maybe we could get this stickied to the top of the section so peole will stop asking "were is your dyno?" or "How much hp does my car make?"
    Basicly this is to help eveyone see what our cars can produce stock, or modded.......
    here is mine.....
    2000 Galant GTZ
    All stock (even had a dirty air filter)
    PS. Make sure they are the corrected #'s too
    Senior TGC Member
    2,175
    Doh...anyone know where I can get mine scanned so I can post it?
    dont have a scanner, but here's my results. Mods at the time were, AEM cai, magnaflow street series mufller.
    ambient temp: 78 deg
    correction factor: 1.02
    Max HP: 164.2 @ 5600 rpm
    Max tq: 164.7 @ 4200 rpm
    btw. 1/4 mile time: 15.9 @ 88 mph. I lost my timeslips so I'm just going by memory. same mods as above.
    GREEN is the new BLACK
    00GTZ00
    Kinkos can scan the dyno papers for you....I think
    my sheet bone stock GTZ temp was 69 degrees and 50+% humidity this was the best pull out of 3
    Wes
    Another fine post brought to you By:
    The Man™
    Search the boards first please!
    Senior TGC Member
    2,175
    <div class='quotetop'>QUOTE(00GTZ00)</div><div class='quotemain'>Kinkos can scan the dyno papers for you....I think Â*:D</div>
    Ah ha! I shall have it done tomorrow...too busy running errands right now It'll be worth it I think...my dyno sheet not only has my best results but it's compared against yours as well, be good for the board I thinks.
    96TEXASgalant
    Anybody in the D.C. area know where a Dyno facility is?
    Kingman
    extreme motorsports in Jessup I think
    EIP tuning in westminster.
    Senior TGC Member
    2,175
    Re: Anyone with "REAL" dyno number post in here...
    Well I found the scanner that came with my computer from 3 years ago...didn't even realize I had one but anyhows...here is my dyno sheet. My result is the blue line, the other two runs are 00GTZ00's runs being compared with mine. My runs were obviously before I had the slip-fit joint welded shut, done in 94 degree weather at 87% humidity: http://www.geocities.com/Area51/Zone/4804/dyno.jpg I don't know how to link pics Hold Ctrl while you click the link to open it in a new page...Geocities doesn't like me using them to host pics for other sites apparently
    cdaw2001ES
    You need to create an index.htm page with you pic on it. The host you choose sucks ass.
    Senior TGC Member
    2,175
    Tell me about it
    newsobe
    how much does it cost to dyno your car ? and anybody know where i can do it in north cali ?
    For Rallifan's link, put a space after the URL in the new window and enter and it will work.
    Interesting and all are Fed. spec GTZ's.
    Senior TGC Member
    2,175
    Not mine, mine is a Cali ES V6, 00GTZ00 can confirm for you As for the price it takes about 60 to 70 bucks for me each run.
